94_240sx »
https://forums.nicoclub.com/94-240sx-u26401.html
Mon Mar 23, 2009 4:07 pm
Quote »The speed works, but the fuel gauge and water temp gauge peg out at full and hot. car was started cold, and the car only has half a tank of gas.
Am I supposed to swap the fuel and water temp units too along with the tach, or is it a bad cluster?[/quote]No, you don't have to swap them. Something's not right.
Quote »Also the turn signal wouldn't work, would that be because it didn't have a full circuit with the four way button still unplugged?[/quote]That's correct. I think blinkers would work if you plug in emergency light switch.
Quote »Also is there a faster way than a drill to turn the mileage? I want to turn it down from 203000 to 142000 so it's matches with my analog cluster. But I don't want to put the one from it in its place[/quote]Remove the clear cover, and black trim inside. There are 3-4 screws holding the odometer in the front and back. Unplug the wiring in the back and you can take it out. Use a plier to undo the little shaft on the left side and you can reset it.
Trust me. Digital cluster is unique and cool, but it's a lot of headache to deal with. I've spent a lot of time and money to make mine function 100% correct. It was kinda flaky, so I had to replace digital display unit with new one, so it should last for a long time. Speed was displaying, but background light didn't come up. It turned out it also powers all background lights too. Yours might work right now, but sooner or later, it'll go bad.
