Right now I'm using a SOHC cluster with a DOHC HUD tach and the SOHC sub-harness on a DOHC car, and it all works fine as far as the wiring and mechanicals. Direct plug n play. As far as the actual tach display, Be aware that if you remove the needle, mark where it was oriented in relation to the
pin (NOT the face). If it doesn't go back on in the same place (on the pin) the tach wont read right, and it's a PITA to fix.
In a pinch, you could always dremel out the bezel a little bit bigger to allow the marks to show. Also if you CAREFULLY ream out the screw holes that hold the tach in place on the cluster, just a tiny bit, you can wiggle it around a little and kinda make it fit better-ish. Best I got w/o having to buy more stuff
