digital cluster on a s13 doesnt work
BookS13
i just bought a 91s 240 with a digtal cluster and the rpm's and the speedometer doesn't work should i replace the whole cluster or could it be something else
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
try checking all associated fuses, if that doesnt work, report back and one of the S13 HUD guys may be able to tell u wat to do, u could also think about gettin a heads up display from http://www.rollhard.com, just an idea...
-Dan
S13240
Does it light up at night? But yes check your associated fuses and check the plugs behind the cluster also to see if they're plugged on the cluster. Or you may want to check your wires, previous owner may have cut them up or something., Everything else on the cluster works fine though correct?
BookS13
S13240 wrote:Does it light up at night? But yes check your associated fuses and check the plugs behind the cluster also to see if they're plugged on the cluster. Or you may want to check your wires, previous owner may have cut them up or something., Everything else on the cluster works fine though correct?
everything else works fine and lights up ill have to see if its a fuse
DOLLARS_AND_SENSE
Car: Money, Cars
If you are going to just get rid of tht cluster or replace it with something else I would be interested in buying it from you!!
slakker
Car: Cars and Comps
does it ever flicker
BookS13
DOLLARS_AND_SENSE wrote:If you are going to just get rid of tht cluster or replace it with something else I would be interested in buying it from you!!
everything else works but the hud and rpm if your intertsted in it email me at [email protected]
