digital cluster issues
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
I've got a 92 hatch with the analog cluster. I swapped it for a digital cluster and the speedo only works when I have the lights on. Also the lights behind the cluster don't work. Tach, fuel, temp, odo, tripometer, dummy lights and whatnot all work though.
Is there something I'm missing here?
nitsujvg
Car: 89' 240sx fastback
i dont know exactly how the speedo is wired but maybe you are supplying it power from a switched source? maybe try rewiring it to acc. or something that stays on when the car is on.
again, i dont know much about the clusters but trying to help!
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
mmm240 wrote:I've got a 92 hatch with the analog cluster. I swapped it for a digital cluster and the speedo only works when I have the lights on. Also the lights behind the cluster don't work. Tach, fuel, temp, odo, tripometer, dummy lights and whatnot all work though.
did you change the cluster harness? im pretty sure when you do this swamp your supposed to get the digital cluster harness to run behind dash over to ecu harness
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
Yeah, I changed the harness
94_240sx
Car: 94_240SX
Power supply is bad. Power supply is right behind speedometer display unit. They are stacked togther. I wasn't able to fix it, but I was able to determine power supply was causing this. You have a bad digital cluster.
splintercell
94_240sx wrote:Power supply is bad. Power supply is right behind speedometer display unit. They are stacked togther. I wasn't able to fix it, but I was able to determine power supply was causing this. You have a bad digital cluster.
damn that sux...id love to get a digital cluster, but so many are bad or will go bad within months from what i hear.
ill just stick with analog.
94_240sx
Car: 94_240SX
splintercell wrote: damn that sux...id love to get a digital cluster, but so many are bad or will go bad within months from what i hear.
But you know, it looks really cool when it works. I like mine a lot, so there's no way going back to analog.
King Ranzo
Car: 15 Ford Focus ST
I have a some what similar problem. My speedo goes off sometimes. My HUD rarely works anymore. Sometimes when I turn the headlights on and the lights come on behind the gauges, the speedo will sometimes go out and so will the lights. I'm figuring it's a wiring problem.
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
I was almost thinking that it's from a SOHC because the redline is a little earlier. Meaning the harness may be a little different and I would have to cut and splice somewhere?
