Digital Cluster and HUD not working
originalyunique93
Car: 1991 Nissan 240sx coupe.
KA24DE
I have a 91 240, and i just recently bought it from a kid for 850 bucks. turned out not to be a bad deal. When i got it the digital speedometer doesnt work nor the HUD. But the tach and all the other gauges like fuel and temp work. But my fuel stops at only half even though i put more than that in it. Anybody know what could be the problem of the Speedometer and HUD? And if it could be replaced or if i could just change it to the analog cluster.
Thanks
slagithor
Car: 1991 240sx
dude i had that problem you can just get an analog DOHC gauge cluster and wiring harness for it. i tried soldering mine and failed miserably. good luck man... enjoy the coupe
originalyunique93
KA24DE
thanks and yeah i was figuring that, how much did all of it cost. Like the cluster and wiring? Is it easy to replace?
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
originalyunique93 wrote:thanks and yeah i was figuring that, how much did all of it cost. Like the cluster and wiring? Is it easy to replace?
It's really cheap if you have access to a junkyard. I did mine for under $75. And it's easy to replace. There's the black plastic trim that is held in by 2 screws. Undo those and it pulls right out, just make sure to use the steering wheel adjuster to drop it down all the way. Then the gauge cluster is held in by 3 bolts. Undo those and it comes right out.
originalyunique93
KA24DE
Okay thanks, theres a few around here, ill probly be checking them here soon.
gigabit240
Car: 92 s13 hatch -sold
98 s14 kouki -current
If you can't find it at the junkyard you might be able to get it from the complete part-out section in the classifieds under the market place.
