digital clock gauge cluster
Spiker
Car: 1990 240sx Hatchback
My digital clock shows no numbers only the backlight goes on. Also my dome light and radio do not turn on. Everything else works fine. The clock and radio didn't start acting up till after I pulled my dash. I know I put everything back the way it was before I even messed with it. My gauge cluster and headlights all light up. I tried to start my car and the lights started to dim so I jumped it. I figured my dome light radio and digital clock were not working because my batt was dead so I decided to let it run abit to charge. Everything works fine with the gauge cluster and headlights but the clock only has backlight still yet no numbers... The radio still did not turn on and my dome light is stupid. She no like give me action. The donme light went out before I even pulled the dash so I guess my batt was weak. Could this be a weak battery problem? If so why does the backlight work and not the numbers? My headlights are fine and I ran the car for 10min still no luck...
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
did you check the fuses? i believe that the clock and radio are on the same fuse.
n240sxfnatic
WOrd, its a fuse. Mine did the same thing and I just replaced it yesterday.
