Digital Climate Controller s13 questions
MoldyOldy240
Car: 1991 240sx 295K w/ original engine.
alright I hope I am on the right track here. I've been wrestling with this for about 2 weeks now... wiring confuses me greatly.
Here are pictures of what I have done thus far. Please excuse the crappy quality.
I started with the harness for the dcc. I spliced in the red wire, I repositioned the green wire, and unplugged the blue cap.z
Then under the glove box I only did one thing; I swapped out the one bit...I don't know what its called, for the JDM piece off the clip I have.
and this is the end result:
it turns on... thats about it. It can engage the A/C unit, but nothing is blowing into my cabin. When I turn my lights on, the unit turns off for a second and then turns back on but is dimmer. I am sure I screwed something up and am missing a big step. I have a whole JDM wiring harness, but I don't know what I need to do next. If any ones knows, and can tell me, that would be sweet.~Nick
iiymij
Car: 240sx coupe
no worries about that we've got a whole thread on this and if you could, could you repost this here as well so we can all the information on the same thread
zerothread?id=94307
I am in the same position as you but is your blower working at all? and can you cycle through the different blower speeds? If not you have to replace that whole gray block piece there with a JDM blow motor resistor i think
Are you also able to cycle through the different positions for the fans like feet blowing, feet and face, feet and defrost or defrost?
Did you also replace your air door mix with the JDM one? its got a metal rod at the end of it, check page 9 of that thread. Let's get it together! =)
MoldyOldy240
Yea, I've looked through alot of the forums, and I will repost this. On the unit I can cycle through different blower speeds, but the blower doesnt even run so...
