S-14boy »
https://forums.nicoclub.com/s-14boy-u2378.html
Mon Jan 12, 2004 6:02 pm
I have had many recent replys to my old post ...http://www.nissaninfiniticlub....a%2Fc... So here goes.
How To Get Digital A/C Controls In Your S-14.(I'm not sure if this will work with early 95 S-14s, I beleive the system is different)Most parts you need are already in the car, the wiring is the main differnce. I redid the whole harness instead of cutting up the harness in the car. The hardest part of building your own harness is finding the plugs to fit, but these plugs are on a lot of nissans in various places on the interior. So heres a list of parts you WILL need (and donor cars I used)1. Japanese Digital Climate Control 2. Plug to fit Japanese Digital Climate Control (from 89 Infiniti i-30)3. Sunload sensor* (from 96 Maxima)4. Plug for Sunload sensor* 5. Ambeint Air Temp Sensor* (from 96 Maxima)6. Plug for Ambient Air Temp Sensor*7. In-Vehicle Air Temp Sensor* (from 96 Maxima)8. Plug for In-Vehicle Air Temp Sensor*9. Aspirator* (from 89 Infiniti i-30)10.Thermo Control Amp (from 96 Maxima)11. Plug for Thermo Control Amp12. Thermal Transmiter (from 89 240sx)13. Plug for Thermal Transmiter * = Not needed if you do not wish the AUTO function to work. AUTO fuction keeps interior at a selected air temperature.-Extra Parts you need to make a new harness14. Plug for Intake Door Motor15. Plug for Door Mode Motor16. Plug for Air-Mix Door Motor17. Plug for Bi-level Door Motor18. Plug for Blower Motor You'll most likely find making a new harness to be the easiest way to do this. You will also need a spool of 20ga wire, butt-conectors or solder, a small screwdriver (from eyeglass kit), Dremmel, weatherstriping, and some time.I will try to post some pics and further directions this week.
