I recently did a digital cluster to analog cluster swap.Everything works perfectly (cluster wise) except now the interior lights (cluster, A/C etc) don't work and they use to work perfectly.
My taillights work and I've checked all fuses.
From doing searches and reading past post it seems that the analog harness doesn't ground properly.
I even found a post where uva240 says:""Also on another note, if you put the analog cluster in and it doesn'tlight up when you turn your head lights on then you will need to somehow contact me and I can tell you what you need to do."
I tried to contact him but no response.
Does any one know a fix for this even if it is a "hack."?
