Darius »
https://forums.nicoclub.com/darius-u5470.html
Wed Apr 04, 2007 3:26 am
You don't have to remove the TB to get the intake side valve cover off. You can tilt it to squeeze it out without scraping paint.
One side note, when you are reinstalling MAKE SURE YOU RTV THE REAR RUBBER CAPS. In fact, pull them out, tear all the old RTV off and lay a 6mm bead across the head recess and then across the top of the plug where it meets the valve cover. That way, you don't have oil leaking and you scratching your head on where it's coming from.
On a second side note, be sure of the paint you are getting. I got mine done a year and a half ago and 700 miles later the paint is starting to bubble up. I'm going to take it back and ***** about it and hope they'll give me my money back. I think it was straight automotive paint.
