Difficulty of KA24 clutch install
turtl631
Car: S14
My stock clutch is going, so I think I'm gonna get an ACT street disc. I want to save money by installing it myself, but I don't have much experience working on cars. All I have is a craftsman 151 piece mechanics set, a jack, and 2 jackstands. A friend of mine has an air compressor, bunch of air tools, a torque wrench, and some ramps, and he's willing to help. Think its possible for us to pull the old clutch and install a new one in one day?
matt4pl
Car: cars, anything fast, graphic design, lots of stuff
yes
Def
Car: Cars, Engineering Stuffs
The only hard part about dropping the transmission is getting to the top bolt at 12 o'clock on the transmission housing. Other than that it is pretty straightforward and not hard IMO.
Get a bunch of wobble extensions though, as I can't see being able to do it without them.
Here's a tip, with the engine mounts bolted down, jack up the front of the engine to gain clearance with the topmost bolt. Should make things alot easier for you(it took me a while to figure this one out).
If you do only have one day, start VERY early and plan to go until night. Also plan to possibly crash at his place for the night and finish up in the morning if you run into any hitches. This isn't a very easy thing to do. Took me 2 leisurely nights to drop my transmission(this isn't my daily driver), so 1 day is doable, but not guaranteed.
My 2 cents on it.
BTW - with the engine out of the car you can drop the transmission in about 5 mins. I was so happy when I could do that on my SR20DET engine instead of fighting with the damn KA transmission for hours on end!
turtl631
Car: S14
Ha..that was succinct. Where are you in chicagoland? I'm on the southwest side and my friend is in broadview. Haev you done your clutch? Any useful tips? I'd appreciate it, especially since you're in the area. Email me at [email protected] if you'd rather not post. Thanks!
turtl631
Car: S14
Well, sounds good. I could do this when I'm at school because I don't really need to drive anywhere, but I don't have tons of tools or car people to help there. By wobble extensions do you mean those flexible socket extensions?
Def
Wobble extensions have a curved end that the socket fits on. This allows the socket to rotate ~16* in all directions from the centerline of the extension. I had to use about 2-3 put together to get at the top bolt and finally break it free. Jacking up the front of the engine gives you about 1/2" more clearance to play with, so that helps alot. It was pretty hard getting the transmission off the input shaft while underneath the car. Make sure you have at least two jacks to support it and at least one helper to spot it.
matt4pl
hey, im over by ohare. i havent done it yet but i will very soon. my clutch gave up today and now totally slips. time for a new one. gotta go drifting
turtl631
Car: S14
Thanks guys, and matt4pl, let us know how the clutch install goes.
matt4pl
might be a while, we're remodeling teh kitchen now so the garage is jammed with junk and no drive way.
DrifterXRPS13
Car: 1993 Acura Integra LS, 1998 Nissan 240SX SE 5sp. KA-T,2004 Honda CBR 600RR, 2005 Suzuki GSX-R 600, 2013 Harley Davidson Iron 883, 2014 BMW S1000RR
i gotta great idea, since there's a couple of us guys here in the same area around chicago, we could meet up and have a clutch removal/installation meet! oh what fun...but seriously i do also have to change my clutch, it slips in 3rd and 4th.
turtl631
Car: S14
thats a good idea actually, share manpower/tools/ideas. Yep, my clutch is sad, sometimes it takes a few seconds to really engage so its like driving an auto transmission :)
matt4pl
hmm, i second that idea. its gotta be within the next two weeks though. drifting on the 11th
