DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Fri Dec 27, 2002 4:19 am
If you're only doing the rotor (not the pads) you can leave the shear pin bolts alone and remove the entire caliper assembly with only 2 bolts. The shear pin bolts are the ones that go through the rubber "bendy straw" boots. If you were doing the pads and not the rotors, then only remove the shear pin bolts. Scottsdale sells brake job kits that include things like pads, shims, grease, rubber boots and caps, lockwires, seals, metal spring clips, etc. It'll cost more, but I like staying factory fresh. I have never had a problem with squeal with only the factory shims.
