180crafter »
https://forums.nicoclub.com/180crafter-u554.html
Mon Sep 16, 2002 1:04 am
the actual installation of the motor is not difficult, but the wiring is time consuming.
make sure you have everything you need first...
You may want to follow my example...
Heavythrottle will convert your harness for you, buy the motor, and install it on your day off (takes a day), and them send out your harnes to get it taken care of... While your waiting for the harness, plug the vacuum lines, clean the motor, install new fuel pump and other goodies.
when the harness comes in, plug it up and you should be good to go.
