differience between a RB25DET and SR20DET
thomasralph
Car: 1993 Nissan 240sx convertible
i wanna do an engine swap in my 93 nissan 240sx convertible i seen a place that swaps both RB and SR what's the difference which is better?
gomer23
Car: 1989 Nissan 240sx
I would search around there is tons and tons and tons of info on this topic, as it has been asked multiple times.
Chezedik
Car: 1991 Nissan 240sx
Ooooh ooooh, me me me, um, okay. One is a straight 6 built similarly to the I-6 motors from datsun. The SR is a 4 cyl. They both use similar turbos, but that is about the extent of the similarity (besides the Nissan logo). If money permits, the RB is the hands down winner. But in my book, if you are looking to swap SR, keep in mind you WILL NOT make the torque that a KA-t might. Just my $.02.
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
Well, lets see, where do I start.RB25 is a 6 cyl. and SR20 is a 4cyl.RB25 is 2.5L SR20 is 2.0LJust exactly what that other guy said. There really isn't any similarity between the two except that they're both made by Nissan.
Red coupe
Car: 92 Nissan 240sx Coupe
where do I start SEARCH DAMMIT!
way different...go read through each section in the engine section...RB is going to cost quite a bit more, and is more fabrication.I researched either of these but from what Ive gathered the SR Basically uses the same motor mounts and mounting location, let you drop it in and wire it up(ok maybe a little more ) and be good to go. IIRC the RB requires custom mounts, and possibly a cross member?An SR swap is in the process of being done some were in the country at any given point....RB25 swaps seem to me a little more intensive.
More people know the SR20 so you would probably impress more of your friends with that...
