Differentials
Hogg
Hey team,
I've heard of a lot of 240SX guys using the Q45 differential in their cars, anyone think it would be possible to put their 4.11 diff into the G50?
If not are there any other alternatives for differentials to increase acceleration?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I hate to sound like this, but this has been discussed ad nausem in the previous posts.. The short story is that theres not really a drop in diff for the Qs.
IMO the diff is not the way to go, high stall TC is way better!
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Hogg wrote:Hey team,
Read the article in the following thread:
zerothread/128658
If you do a search, you will find many threads covering this subject such as these:
zerothread?id=197948http://forums.nicoc ... ?id=194980
mxr662
Car: 1990 Q45 Desert Sand 81k Sold
captainluigi
Car: 1996 q45t
all mouth, not trying to bust your balls or anything such. just want to ask you if you know about the SEARCH function. of all the auto tech forums i personally have been a part of this one is heads above the others. all here(read most)are here to help but they will remind you as i am doing now to USE THE DAMN SEARCH FUNCTION. you will find that it will yield MUCH more info for your digestion & answer questions you have not even thought to ask yet. meanwhile,
GLK
GseaQ
I've got a 4.08 that I just recently took out of our "new" '95 in favour of the original 3.54. Most of my driving is highway. The 4.08 really does make the car seem "lighter" around town.
This particular, specially built only for the Q45, 4.08 diff is a simple bolt-in. A previous owner of the car who is also a NICO member had it built at a 4x4 shop about 3 years ago. Like I said, it's a bolt-in which means it has the correct flanges for the driveshaft and the axle CV joints. From the day it was built it had a bit of a whine, but should just be a slight adjustment of the spider gears if the noise bothered you (my mechanic said they're probably just a bit loose).
Glenn
Modified by GseaQ at 5:22 PM 2/19/2008
superuber
The 4:08 (300z) is NOT a bolt in on the G50.
Rex
Car: None
superuber wrote:The 4:08 (300z) is NOT a bolt in on the G50.
The one he's referring to is, it was bolted into his newly acquired Q45 (G50) until he swapped back to stock.
superuber
So, any 4:08 will work in any Q?
GseaQ
superuber wrote:So, any 4:08 will work in any Q?
No, the output flanges have to be retro-fitted from the original (I think) as the Q has 6 bolt flanges & 300Z has 5 bolt flanges (or vice versa). There might be something else, too, with the input shaft - can't remember.
Glenn
Rex
Car: None
Nope.
It was "built for the Q" by a shop for the previous (NICO) owner, I was just confirming he has a non stock (4.08) rear that is bolt in if someone wnats to buy it.
Q45tech
Built in that it takes 5-8 hours of highly skilled experienced labor [plus parts] to create a 4.083 that matches [drops in in place of] the Q45 diff.
superuber
Q45tech wrote:Built in that it takes 5-8 hours of highly skilled experienced labor [plus parts] to create a 4.083 that matches [drops in in place of] the Q45 diff.
Been there, done that!
GseaQ wrote:This 4.08 diff is a simple bolt-in.
My point in asking the question was a statement like this can be misleading to a newbie. So he runs to the local bone yard,spends $375 on a 300 rear and viola, no fit! Lets try to be more specific.
GseaQ
I edited my post for clarity. Check it out for me. Tks.
superuber
