Slappy wrote:Read
http://forums.driftinginsider....t=597
"You should only use conventional GL-4 80w-90. I use Nissan brand, because It's cheap, quality, easy to find and meets all of the requirements. Change it every time you change your oil. Do not use Redline, Royal purple, or Motul. Do not use any LSD additive."
The quote from this thread is very mis-leading also! Nissan actually recommends GL-5 instead of GL-4 for their differentials. IIRC GL-5 has some extra high pressure additives which is good for reducing gear wear, but this increase of these additives increase synchro wear. Since, you do not have any synchros in your differential, GL-5 will work just fine. Why the heck would he not recommend a quality sythetic, besides the potential for leaks? Perhaps if he ran a synthetic, he would not have to change it so often!
