Sil40_Mayhem »
https://forums.nicoclub.com/sil40-mayhem-u9449.html
Thu Apr 20, 2006 10:44 am
While I'm probably the last guy that needs to be giving mechanical advice, I'll take a shot at it. Unless you don't wish to disassemble your diff, why don't you just swap in a ring gear with a shorter ratio? I believe the final drive ratio in CA18 equipped S13s is 4.11. I know that in NA 300ZXs and 240SXs, the ratio is 4.083. It looks like the stock ratio for the J is 3.92, which would mean that the other aforementioned models should give you better acceleration (at the cost of top speed).
As far as diff swapping, the reason I enquired about changing the ring gear is that all Js come with vlsd. Since it seems that the majority of 240s come with open diffs, I don't see the benefit of slightly improved acceleration at the expense of "peglegging" (which, trust me, sucks the big one). Of course, the 300ZX diffs are of the vlsd variety, so you should be good there. Also, you wouldn't have to worry about matching the output shafts to your axles, driveshaft length, ABS sensor, etc...
Other things to consider:- your diff's ouput flanges are a 5 bolt pattern; you will either need to find a replacement that has the same pattern, or you might need to replace your axles with those whose pattern matches your diff- your car has ABS; you may want to look for a diff that has an ABS sensor (if that's important to you); also, this might affect the connection to your driveshaft since diffs with the ABS sensor are a different length from those without, which may require repositioning or even replacing the driveshaft
This is what I've picked up while researching the diff swap from the other way around (J30 diff -> 240SX). I may be wrong about a bit of it (hence why I said that I'm probably not the best suited for giving advice). Anyhow, take a look at the diff swap articles we have here (and maybe other sources on the net), and reverse the information where it applies (particularly those pertaining to the J30 -> 240SX swap). Anyway, I hope that at least helps some.
By the way, unless I missed something, all J30s are autos from the factory.
