240sxrb25det »
https://forums.nicoclub.com/240sxrb25det-u9541.html
Tue Nov 16, 2004 8:32 pm
hmm now im confused, the ring gear on the q45 diff was the same inner diameter (measured with a dial caliper) and fit on the lsd pack of my s14 perfectly, ive also read in a couple articles that stated the q45 to have a 200v i dont know if there are certain years with different ring gears.
however the outer diameter was larger than the 4.08 gear ring so i was gonna swap the rear cover, because the cases are the same size, the bolt holes on the case cover line up as well.
also where is the crush washer. and are the shims the ones on the sides of the bearings? because if so then they were all the same arangement one thick one on one side and a thin one on the other.
any info appreciated Dane
