exvin wrote:So does that mean that when it is in 2wd, only the two rear wheels are moving or only 1 rear wheel that is powered. if it is two wheels that are powered, they move at the same rate right or no?
technically no, the power to each wheel fluctuates depending on road conditions, and as far as rates, yeah they spin at the same rate in a straight line, but very different rates when youre turning. The inside wheel is always going to make less revolutions than the outside wheel in a turn.... if u ever meet someone with a locked diff, have them make a turn on asphalt, it will screech the tires even at 5 mph
Quote »When we are engaged in 4wd, the crack shafts which is driven by the transfer case, is it driven by the same rate, or different or specified rates? [/quote] automode is an electronic nissan system, anywhere from 10/90 to 50/50 depending on amount of slippage 4wd is 50/50
