Not at all, you did well. I am a little concerned if there isn't addtional damage to your rear subframe or differential carrier. Better keep an eye on the silicone filled bushings.lasoyafan wrote: Sorry for posting in the wrong forum. BTW, I'm a newb here!!!
haha sorry caps lock got turned on. Where could I find new bushing if some are damaged? The wheel still sticks out a bit but I'm going to get it aligned today so we'll see if that does it.maxnix wrote:Not at all, you did well. I am a little concerned if there isn't addtional damage to your rear subframe or differential carrier. Better keep an eye on the silicone filled bushings.
BTW, even the old geezers here can read, so you don't need to SHOUT!!! (See changes to above quote.)
