Andrew224 »
https://forums.nicoclub.com/andrew224-u74975.html
Mon Sep 08, 2008 9:15 am
Thanks, but I don't think it's a 10mm. I'll have to re-check when I have a few minutes to slip under the car. When I was all set to do it a couple weeks ago, 10mm was too large and 8mm was too small. I don't have a 9mm hex bit socket. Seems they are special order only items. Craftsman doesn't even make one. (The Craftsman set I have, has 4,5,6,7,8, and 10. Why they skipped 9mm, who knows?) No one I know has a 9mm hex bit socket that I could try out.
I thought that maybe the first generation Ms for the U.S. had sizes that were more common for overseas (Japan) seeing as the M was around there a lot longer. Maybe 9mm hex isn't rare there? Or maybe it is a 10mm and I just didn't give it a chance.
Before I go and special order one socket for $30 (after shipping and handling), I was hoping someone could confirm.
On my QX4, you don't even need a socket. The rachet (or cheater bar) head fits right in there. I saw the metal shavings and a piece of flash stuck to the plug magnet. Made me concerned with getting the M done soon (35,000 miles).
I'm switching to Mobil 1 full Synthetic 75W-90.
Andrew
