the Q final drive is pretty tall and it will definitely change your shift points. for drag you basically want to a usable 1st and 2nd, end your run at the very top of a gear. these all vary depending on your turbo/hp, powerband, tire diameter, launch control, etc.
the spreadsheet at the end of this writeup used to be useful, but now the link is busted.
install-guide-q45-differential-swap-int ... 67924.html
with something similar, you can calculate your own ideal diff ratio. i think very high hp drag racers use the Q 3.5/3.6 or the pathfinder 3.1 diff.
http://zilvia.net/f/s-chassis/267957-tu ... assis.html
i would start by figuring out what your trap speed is, then what your max rpm is, then your tire size, and finally figure out which FD is the best for you.
