Differential oil
supersnake83
Car: Infiniti J 30
Hi everyone,
Does anybody know how to change differential gear oil.
If anybody knows, simple directions would be great.
Thanks,
Geoff.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
take drain plug out, drain oil, replace drain plug to proper torque, take out top filler plug, and add proper amount of fluid...
It really is that easy..
yodawill2000
Car: 94 Infiniti J30
manual says 3.8 Pts ..Is that about when it comes back out the fill hole ??
Just curious .. thats how I filled all my truck diff's
supersnake83
Car: Infiniti J 30
I don't mean to sound silly, but where is the drain plug located and where is the refill plug located.
I take your word for it being that easy, but I have only changed/filled engine oil and transmission fluid; never have I changed differential gear oil before.
Thanks,
Geoff.
Q45tech
When you find the refill hole [leftside rear near top of diff], make sure you can remove the refill plug before draining out the old lube............otherwise tough to turn the entire car upside down for filling from the drain.
DominickJ30
Car: 1993 Infiniti J30t
How about a pump for refilling?
NismoChi
Car: 94 J30
Q45tech wrote:When you find the refill hole [leftside rear near top of diff], make sure you can remove the refill plug before draining out the old lube............otherwise tough to turn the entire car upside down for filling from the drain.
What he said.What he said.Hope these pics help. Pink is the filler plug and green is the drain plug.also, get a hand pump from kargen, it'll make the job a lot easier.
DominickJ30
BTW what kind of diff oil to use? Q45Tech, do you have any preferance in diff oil and or additives?
Q45tech
The differential is the single highest friction part of the driveline at low speeds especially from a standing start!
You don't need any additives as the VLSD is a sealed internal unit.
A PREMIUM Synthetic diff lube is best changed every 2 year [30k].
Redline or Mobil 1.
DominickJ30
You have a different differential than me cuz my drain is on the bottom of the diff not back...
R200??
nevadachuck
Car: J30
There is a drain plug and a fill plug. Been a while since I did it. If I recall, I used a length of tubing into the fill hole and squeezed a bottle (seems like it was almost 2 qts.) of warmed diff (ltd slip) oil into the tube which I held up near the roofline. Snake the tubing (plastic) through the wheel well - etc. etc.
elwesso
2007 BMW M Coupe
DominickJ30 wrote:You have a different differential than me cuz my drain is on the bottom of the diff not back...
R200??
They changed the design the latter part of 94.. on my 94 Q the drain is on the bottom, but on my 95 Q it was on the back.
