differential gear oil 04 titan
titanup
Car: 2004 Titan LE
I called the dealer and ask what they recommended. They told me 75/140synthetic, it's $18 a quart. Any input?Thanks
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Given the number of rear end failures in early Titans, I would follow their recommendations, though you should be able to find the same lube in the parts store for less. Do you have the finned aluminum rear diff cover on your truck? If not, that's a good upgrade, as it allows for additional oil capacity and cooler running temps.
titanup
Car: 2004 Titan LE
Thanks, I apprecite your time and helpful comment
