Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Nov 11, 2003 3:09 pm
The 97-01 has a 3.694 rear gear so the 10.4% increase would be less noticable than on the earlier 3.538.
Whether the newer 3rd case [1st gen -90-93, 2nd gen 94-96, 3rd gen 97-01] will accept gears from the 300zx manual non turbo diff is unknown. Whether the entire diff can just be substituted is unknown..........they all look and mount similiarly but never measured the 97.
You will need plastic speed sensor correction gear to match the 4.083 [from Nissan dealer].
Swapping gears [and getting them set up] is much harder than swapping the entire diff ............at least on 90-96 models.
