maxnix wrote:Much more efficient to walk under the car when it is on a lift.
Wish I could do that. It would make things easier for this car as well as the 1967 MGB GT we are mechanically restoring as well.
The job is done. Had to use the muffler we chopped off the mg as a breaker bar extension which worked like a charm. It broke the drain plug loose enough to start and then I used the the breaker bar to hit the ratchet to finish getting it out. The oil didnt look too bad at first glance, but when it was all out and in a clear plastic bottle it was pretty dark, way over 30k.
