Differential Drain Plug Stuck
rob1
Car: 1994 Q45
Refill plug came out easy, but the differential drain plug is stuck. Car is cool but not cold. Any tricks?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Must have an exact fitting Allen wrench.
Don't know how a steel bolt plug can get stuck too bad into an aluminum casting unless it was cross threaded.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Theyre not allen... Theyre 1/2 in square thingy.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:Theyre not allen... Theyre 1/2 in square thingy.
Yep, memory goes quickly after 24 hrs. Even easier to get a good fit.
rob1
Car: 1994 Q45
Everyone is saying to use a 1/2 inch ended racketed which worked fine for the refill plug, but even with a 3 foot pipe extension, the plug won't budge. I don't what damage the plug or worse the differential housing. I was hoping there was a trick like remove when care is cold or hot. The mechanic who change the fluid last time must of over tightened.
I am assuming traditionally counterclockwise for removal.
elwesso
2007 BMW M Coupe
Often what you gotta do is get your 1/2in drive wrench and give it a good whack with a hammer... Make sure its in there real good..... and then hit it..... Sometimes they need that instant blow to get them to go.....
chinaonnitrous
Car: 2002 Maxima to 2004 Evoloution to 1992 Integra
Exactly!! On older cars, a shock is sometimes needed to break that super ancient, corroded, crap around it bolt. Thats why impact tools are so useful. Throw the wrench in there, give the head a few hard bangs with a hammer to shock it, and whack the handle a few times too. That should help. Being cold would probably be the best, since metal somewhat expands when warm.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
rob1 wrote:Everyone is saying to use a 1/2 inch ended racketed which worked fine for the refill plug, but even with a 3 foot pipe extension, the plug won't budge.
I would say get a tool with the precise fit (square drives have rounded corners) and use the impact (hammer) method once the tool is properly seated with a light blow from the hammer.
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
I had a little trouble getting my drain plug off too. I just put pressure on it, and then pushed and hit the wrench with the palm of my hand at the same time. Doing those two combined will get it off with ease.
.........[and please.... no minds in the gutter mmkay? ]
chinaonnitrous
h
Ev_eezy wrote:I had a little trouble getting my drain plug off too. I just put pressure on it, and then pushed and hit the wrench with the palm of my hand at the same time. Doing those two combined will get it off with ease.
now that you suggested it, that is kinda nasty........
elwesso
2007 BMW M Coupe
evan's mind is always in the gutter
