Q451990 wrote: ↑Thu Mar 29, 2018 9:38 am
More penetrating oil with an overnight soak time, and maybe a torch are the best ideas I can come up with... Is the differential on the 98 a steel housing or aluminum? Someone who knows more about metal might have ideas on the expansion of the steel bolt vs. the housing would react during a torch session. Torches are relatively inexpensive.. less than $20 at Home Depot and Harbor Freight.
Thanks for the heads up. Not sure if it’s aluminum or steel, but I think it’s steel. It was rock solid that’s for sure. Idk if the fluid was previously changed, but it had some orange putty around the bolt. I was putting tremendous amounts of force, and I lift weights! s*** was not budging. Almost like how I had to take a strut tower to bang off a sealed on thermostat housing at the junkyard. This car has beat me up more than twice, when it comes down to normally simple tasks lol.
This was a great project for me to get a chance to look at and spray lube every possible rear rubber bushing I could see on the rear. But I caved in and just ended up paying my guy to do it. It was a little more than $50 but less than $100. I was okay with it. I explained to him I just couldn’t get it off myself, so he kinda helped me out.
I would feel cheeky asking to just loosen the bolts. I always feel if I have to give it to a mechanic to do part of the job, I might as well let them do the whole job. Maybe down the line, I’ll try it again on my own. But not for another 50,000 miles atleast. The fluid was dirty, but not metal shavings.
