Plenty in the previous posts, but most concern the F50 and G50. All Nissan differentials differ slightly, especially in the Infiniti series. No simple bolt ups, many difficult ones.NYCQDude wrote:Nobody has any comments on diffs?
Thank you all for your responses. I am actually going to skip the swap for now Thanks to QSIGuy's experiences with the larger rear. Will stick with suspension (found a pair of NOS Eibach's!), breaking (bought some cross slotted/drilled rotors and ceramic pads) and some new wheels. Might do the Jet chip upgrade as JW and NICO do not make chips for the '97. Put together a makeshift ram air intake. very little difference at idle up to a few thousand, but once I push the pedal I do get a bit more aggressive acceleration (and it sounds cool lol)...qsiguy wrote:I put a 4.08 on my '94. Not that big of a difference so don't get too excited. It's not going to make you do wheel stands off the line or anything like that. I am planning to put my OEM diff back on at some point in the near future. Plus with my turbo I think I like the powerband better with the stock rear end. Highway RPM @ 65 is also higher than I like, It's like driving down the highway with the gated shifter down in 3rd instead of 'D' when you are in stock form.
