yeah...its pretty darn easy to take off the valve cover...clean it with a metal sponge/soap and i used High-temp Paint from Wal-mart...irichjohn wrote:hey did u paint ur engine?was it easy to take it out & wat kind of paint?
Yeah about this topic...i ended up buying a set of gator grip sockets...good stuff except i didn't have enough clearance to work with them. So i ended up cutting it off.Rex wrote:If the sockets designed specifically for removing stripped nuts won't work, you're only choice is brute force or a cutting wheel. I have seen people pound the wrong size socket on bolts and them remove them, but the socket is pretty much trashed at that point.
Good luck and report back what actually works.
take about 20 minutes....Fla240sx wrote:blow torch
really? takes me about a minute, maybe you need better torches?S3t0_S13 wrote:
