Woohoo! My 1st post. Anyway, a short intro about me. The name is Alvin from Malaysia & I drive a Cefiro A31. Recently my RB25det motor decided to die on me. It was kinda my fault actually. Oil pump was faulty and I kept pushing the car without knowing the problem. Didn't have the right gauges to read the oil pressure too. Car was pushing at least 400 hp and the inevitable happened, bearings ate out and crank kapoot. Reading from the RB section, I could fix it with an extended crank collar and some machining work but I decided to put the RB motor down and go with the 'There's no replacement for Displacement' theory. The VH41.
I've done some reading on the VH motors but I still can't differentiate these VH41 motors. Most threads I've found has broken link for pictures.
So, I found 2 VH41 engine from the local chop shop. The 2 motors has different intake manifold and my question is, what's the difference between the 2? There's pictures below. Are these 2 engines the JDM and US versions or just newer and older versions?
and this
Please HELP! Would really appreciate the help. Once I've got the answer, I'm going to start my V8 journey.
Thanks!
