Different rear brake pads for power or manual parking brake?
Leo1818
Car: 2018 Nissan Rogue
On Bosch's website., They have two different part numbers for 2018 rogue rear brake pads. They list one for power parking brake, the other one for manual parking brake. Are they really different? Are the other manufacturers or Nissan also having it this way?
Thanks a lot.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The manual brake on gen2 Rogues is a drum-in-disc setup with separate shoes for the parking brake. Electric parking brakes use actuators on or in the caliper to clamp the pads to the rotor. Some OE's actually do use different pads for electric, since the actuators "screw" into place and the turning of the piston requires a modified backing plate for some designs. To my knowledge, that's not true of any N/I models. The second part number you're seeing may be for the shoes on the manual version.
Leo1818
VStar650CL wrote:
Fri Jun 25, 2021 8:41 pm
Thank you so much for the information. But i remember 2018 rogue should all use disc rear brake. Other websites all list it as pad, not shoe. Very confusing.
VStar650CL
Technical Expert
They are all disc, but the manual e-brake version has a drum inside the hub of each rotor with a set of shoes, completely separate from the main braking system. The electric version uses the primary pads and rotor for both functions.
Leo1818
VStar650CL wrote:
Fri Jun 25, 2021 10:37 pm
Thanks again. That makes sense now. I just got chance to jack up my rogue. It is a motor-over-piston type power brake as you said. So I guess the difference between power or manual parking brake pad is the back plate of the pad. The piston of power brake model is not regular circle one. Bosch's brake pad has their back plate installed as one piece(so you cannot re-use the old back plate) so they list them two different part numbers.
VStar650CL
Technical Expert
Yep, that makes sense. :)
D1dad
Car: 2021 Nissan Altima SR
2018 Nissan Rogue Midnight
2009 Nissan Altima SL
I assumed my 18 had a manual parking brake so that’s what I installed. No issues to date but really didn’t pay attention to the pads and rotors. I wish Nissan would use a larger pad on the rear so the pads don’t wear out twice as fast as the front.
D1dad
I guess I should have said that because I have a pedal to push down beside the brake pedal that it was manual.
D1dad
D1dad wrote:
Mon Jun 28, 2021 4:03 am
I assumed my 18 had a manual parking brake so that’s what I installed. No issues to date but really didn’t pay attention to the pads and rotors outside that they matched the old. I wish Nissan would use a larger pad on the rear so the pads don’t wear out twice as fast as the front.
VStar650CL
Technical Expert
D1dad wrote:
Mon Jun 28, 2021 4:10 am
Yep, that's a correct assumption. If it was e-Park you'd have a switch and not a pedal.
Return to “Rogue Forum”
