I was thinking coil(s) at first, then I read the symptoms of spark plug blow out and they pretty much match mine. So I got back confused.eh? wrote:11 psi on a stock turbo isn't much. Have you checked your coils? When you part throttle does boost still hit 11psi?
Ok, I'll change my plugs to bcpr7es @ .8mm and while I'm in there examine the coils.eh? wrote:Sounds like coils to me but I have my bcpr7es at .8mm. I've always had them like that regardless of boost level and turbo size.
See, initially, fuel cut is what I was thinking (from the VERY beginning). It's in 3/4/5th gears only @ WOT.RustspecS13 wrote:When I swapped in my rb20 I didn't hook up my 4/5th gear sensors.
During long 3/4/5th gear pulls my fuel would cut out for a good 5-10 seconds until the ecu returned fuel/power. If I started in 3rd it cut out mid/top of 4th and if i started in 4th it would do it top of 4th or any where in 5th.
It does this because it thinks its in neutral all the time and the ecu doesn't want the engine at full load in "no gear" so it cuts fuel.
If it was spark blow out it would be more inconsistent, but a solid lack of all power is more likely a fuel cut.
~Alex
Ah, ok. So it'd basically be like a "skipping" feeling vs. a instant drop in power?WhatsADSM wrote:yea full out cutoff in power is typically not spark blowout. Spark blowout is more of a random miss feeling at WOT.
Do you have the stock intake tubing? Cause it is probably collapsing in on itself. My SR used to do that until I changed it. Felt like hitting a brick wall.RustspecS13 wrote:Exactly, I was going to say something to that effect. But I god distracted lol.
~Alex
Ok, I'll do that.Cjmartz2k wrote:Ignition is always about the weakest link. I don't feel like typing everything again, so search coil packs and look for a LONG post I made about ignition. If you need a set of SII coil packs, email me. I've got some.
There is no difference between new splitfire coils and new OEM coils. I've never run anything but junk yard RB coils coming about of everything from an RB26dett to a RB20de. They are all the same, except the RB20de ones tend to be in better shape since they never really got heated up and beat on like the RBxxdet(t) ones. The reason people see an improvement and think splitfires are better is because they are replacing old worn out coils with brand new ones. OEM RB coils in good shape are good to WELL over 600+rwhp.TwoJayZee240 wrote:From my exsperience the Rb coils seem to be weak, but i have heard of people running them to 500hp. I see some Splitfire coils in my future. Hope this helps.
