to me, i like longer gear, it keeps me in boost longer and not shifting as sooner than shorter gears do. this is crucial for folks with higher power output. that's why the q45 3.5 is my choice, I won't be running out of gear before you and it results in higher top speed before running out of gear. just think about it, boosted car really doesn't matter, because you are under load and spin through 1st, 2end, 3rd fast anyways..shorter gear will not help either. who cares about off the line when you're launching at 4-5k rpm
this all applies to drag, but for x-cross, it's a different setup, you want shorter gears for quicker response.
wawazat8402 wrote:
Agreed. I hit 145 in my FB one time and it was a handful and a half. It definitely helped me make the decision to pick a different car for my goals on the Texas Mile.
I found out that going faster is much less scary than trying to slow back down from going too fast.
that's why the proper upgrade for your power range is supposed to go in hand with proper braking upgrade.
Modified by BoostFab at 6:32 PM 12/5/2008
