ThisIsSparTTa »
https://forums.nicoclub.com/thisisspartta-u210180.html
Mon Jan 14, 2013 8:21 pm
A quick background, I bought my 91 TT about 1500 miles ago, and it now has 166k miles. When I did, my local Z shop identified a bad injector on 6 that I had him go ahead and do via the dremel method. I have no baseline for comparison, but after this she was running pretty solid and had lots of good pull.
Previous owner didn't understand what had been done to the car, but here's what I've found, if it helps: Intake, Flashed ECU, Boost at 14 PSI, AFC, Down-pipes, performance cats and catbacks.
About a month ago she starts to run really rough. Initially it was backfiring, low power, etc. Initially, did a power balance did test and found problems on 3 and 6, also when playing with the PTU sub-harness I found that the engine nearly died. I cut the engine to visually inspect the PTU sub-harness, and after it wouldn't crank, I played with sub-harness some more and it cranked again. At this point, without changing anything it was running normally again (no backfiring), so I chalked it up to a problem with the PTU-subharness that needed to get fixed. A few days later it started running like crap again, doing the same stuff minus the backfiring.
First thing I did was cut the PTU-subharness connector and directly solder the wires together per advice from my local Z club and Z shop owner. I no longer get the engine dying etc when moving the cable. Also, for future, I check the voltage on all the coil connectors and was getting ~13V, so I think they're getting power.
However, engine is still running terrible. Now power balance is failing on 3 AND 5, but 6 seems to be okay. The spark plugs were in an unknown state anyways, and likely had at least 20k on them based on when the previous owner did their last batch of maintenance, so I got some PFR6B-11Bs (which is what it had previously), and replaced them. Problems remained on 3 and 5, basically the same behavior.
Swapped coil pack with 3 and 2 (opposite sides) and problem remained on 3, and 2 seemed fine. Also quickly tried 2's coil pack connection on 3, and it didn't seem to do anything. Didn't bother swapping 5 after this. As I noted above, I also measured all 6 coil pack connectors and found them to be have ~13V on the left and middle terminal.
I ohmed the front 4 injectors (didn't feel like pulling balance bar tonight), and 1= 24ohms (high, yes I know), 3 = 45ohms, 2 = 12ohms, 4 = 14ohms. I will note that listening to 5 with a mechanics scope sounded VERY weak compared to the others. 3 did sound okay.
Where I'm at right now, I think its time to replace all 6 injectors (I'll just replace the one already done to be sure since I'll have it off, and it was having an issue initially on power balance test). However, I think it is weird that the problem moved from 6 to 5, which is the only thing that makes me hesitate. I think its pretty clear 3 needs a new injector, 1 is a little high, and 5 also looks like a bad one. One last quick note, I checked ECU after problems began, and there were no codes, haven't tried again since then. Is there anything else you guys think I should give a shot first? Any other advice?
Thanks for the long read, figured it would be easier to give all the information you guys always ask for up front rather than in pieces.
