SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Tue May 09, 2006 3:09 pm
The ABS driveshaft is about an inch shorter. The sensor for the ABS is in the rear differential and makes the ABS diff about an inch longer. Look at the diff where the driveshaft goes into the diff, you should see a sensor there if it is an ABS diff, otherwise no sensor means it is a non abs diff.
