That is TOTALLY wrong... As S15 Silvia's go the Spec-S is the non turbo version & the Spec-R is turbo. I don't know where the hell they're getting their information from. That needs to be revised.
I think the op means to ask about the difference between the blacktop T28's as there is a difference between the S14 T28, and the S15 T28, The S15 being a bit stronger.
"The third generation(S15) received a more refined T-28 turbo. The compressor was the same BCI-1 wheel put inside a T04B housing, but the turbine received an upgraded inconel wheel and had a cast divider wall in the wastegate discharge path to help aid spool characteristics."
zerothread/306956
Edit: I sent them a nice email, so hopefully they fix it
Modified by PantherRacer at 12:21 AM 2/19/2010
