s13 "DE is a different head than s14 "DE" OBD-II head at the valve cover however I am unsure about the early s14 OBD-1 heads. The cams from the majority of KA "DE" engine family are interchangeable with the preferred cams being early 240 s13 "DE" engines and or a combination of s13 "240"/s14 "232" cams. The link to all your Nissan factory cam profile and personal preferences:
zerothread/152578
As for manifolds, the only main difference i am aware of is the butterfly valve located within the manifold. s13 "DE" engine have them, I believe the s14 "DE" do not. It is also believed that the manifold without the butterfly valves (s14 "DE") may yield better performance numbers in the mid to upper rpm range due to Nissans' decision to remove the valves in turn increasing air flow.
As for the remainder of the engine, the block will accept just about any part from an KA "DE" equipped vehicle. The larger difference in components is between FWD to RWD vehicles. Secondly, the type and year of head and its valve cover.
