Differences in pistons. Please help with info.
theboz
Car: 1990 240SX coupe SR20DET, 1995 S14 SE DD, 1995 Civic Hatch, 1993 GMC 2500HD, 2004 Suzuki XL7
I have a bad piston in my SR. I bought a stock piston and it is slightly different than the one I am replacing. The stamping is different on them too. The biggest difference is the cutout for the oil squirters. I did a search and couldn't find any info. Any help would be appreciated. Can I use this piston with the other three that are in the engine without hurting anything? Is the difference just the year of manufacture? I am in the process of rebuilding. You can see the diffferences in the pictures. Thanks,
BoZ
theboz
The stampings.
Dori Dori
Car: Cars of course
54c's were the better pistons from blacktop SRs (all; s13, s14, s15). The oil squirters in the block were aimed better to take advantage of the newer piston design.
Nismo_Freak
Car: 89 Nissan 240SX
Dori Dori wrote:54c's were the better pistons from blacktop SRs (all; s13, s14, s15). The oil squirters in the block were of a better flow design, and used in conjunction with a gallery style piston.
+1
Take a picture of the back of the piston and I'll point something out to you.
theboz
Pic of bottom of both pistons.
Nismo_Freak
theboz wrote:Pic of bottom of both pistons.
Notice the two small holes in the bottom piston. That allows the oil squirter to spray oil deeper into the piston, making cooling more efficient.
Dori Dori
Car: Cars of course
^do you know if (any of) the aftermarket pistons take advantage of the updated design?
Nismo_Freak
Dori Dori wrote:^do you know if (any of) the aftermarket pistons take advantage of the updated design?
Yes, Tomei makes pistons that are called "Cooling Channel Type" which feature the above design.
vboyq
hey anthony its me quang.. man i haven't been in wpb or by tertech in like a year...next time i head back ima hit you guys up!
Dori Dori
Car: Cars of course
Yeah man. The old shop is gone. Actually "ter-tech" is no longer a shop per-say. My number has changed so email me at amacaluso@gmail .com
theboz
So is it going to hurt anything to put the blacktop piston witht the three redtop pistons? They should basically be the same besides the oil squirter cutout and the cooling channels, right? Please let em know something as I will be putting everything together this coming weekend. Thanks
Nismo_Freak
theboz wrote:So is it going to hurt anything to put the blacktop piston witht the three redtop pistons? They should basically be the same besides the oil squirter cutout and the cooling channels, right? Please let em know something as I will be putting everything together this coming weekend. Thanks
Weigh the pistons, make sure they are similar.
