evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue May 25, 2010 9:25 am
the oil sender is ont he opposite side but when you put a jdm engine in your swap it over, there si a plug int he usdm side you simply swap the plug for the sender, the plenum has the vac booster fittings ont he wrogn side you simply swap them over as well
the tps iacv and all other sensors are exactly the same
adjusting the cas will adjust your ignition timing, adjusting ti will help if your problem si incorrect ignition timing whihc I doubt and even then you should not be adjusting it wihtout a timing light!
no jdm manual because its the exact same motor they simply had to move a few things to fir the rhd chassis
no that we've cleared up your miscelaneous questiosn we can actually troubleshoot your car
step1, check the ecu for codes
step2 verify taht the car si runnign on all 6 cylinders (with the car running unplug each cop 1 at a time, this should cause the idel to drop or the car to die if not you have found a cylinder that does nto work
step3, let us know the results of step 1 and 2
