if you have the time, more power to ya!NSR A32 wrote:I didn't delve into the 00vi. Sounds like another research topic for Tuesday as I'll be sitting in front of my computer all day on my day off.
OH SNAP! Good article Kenny.nsrZ32 wrote:Woo hoo! Kenny's lack of a life pays off. Way to be man!
you would want to use the 01 pathfinder VQ35 TB. Using a 5.0 gen (2000-2001) maxima TB wouldn't do you any good because they're 60mm just like yours. The Pathy TB is 70mm and with a few modifications it works just fine. The VQ35DE maxima TB's are also 70mm but you would not want to use those because they have drive by wire, aka electronic throttle, and you have a cable throttle.DjNikos wrote:awesome write up. Bravo bravo. I just have a question to ask though. Would a 2000-2001 maxima throttle body swap directly into a 96 maxima? Im willing to try and post dyno sheets from my car if it actually works.
also, on my search of throttle body's I found this on ebay. I don't know wether its another scam on ebay and wether its proven or not. Wether it makes a diffrence or not. although this isn't directly related to the topic, its still on the throttle body topic.
http://cgi.ebay.com/ebaymotors...QrdZ1
and one further question, would replacing the stock throttle body with....say 100mm aftermarket give me a performance boost?
Modified by DjNikos at 6:04 AM 12/8/2006
That's what I would do as well. Better all around, no loss of low end torque, and easier to get your hands on (there are gobs of them laying around in junk yards)NSR A32 wrote:
Better off finding an 00vi.
So, the intake manifold [00vi(meaning a 2000 maxima?)intake manifold] will bolt right up to the fourth gen?NSR A32 wrote:Better off finding an 00vi.
and if it does bolt right up, how do i get the variable manifold to be uh variable?NSR A32 wrote:Since the 4th gen Maxima ECU isn't programmed to open the intake manifold using signals it receives from the engine like the 5th gen Maxima, an option for a variable intake manifold on the 4th gen is using the 2 stage variable intake manifold from the Cefiro, the Japanese and Middle Eastern version of the Maxima. It uses vacuum pressure to operate instead of the ECU.
Correct. The IM you want is from the VQ30DE-k from a 5.0 gen maxima (2000-2001) However it's not so much a bolt-on mod but it's definitely doablejltibbs wrote:So, the intake manifold [00vi(meaning a 2000 maxima?)intake manifold] will bolt right up to the fourth gen?
There's a couple different methods of installing the 00vi and it all depends on what you want. For example, if you want to use the 5th gen or 4th gen lower IM or if you want to keep EGR, etc. To activate the VI you need something like an RPM switch and most people use VAFCII to control their VI using the VTEC function. Here are some pretty good reads on the subject:jltibbs wrote:and if it does bolt right up, how do i get the variable manifold to be uh variable?
