Differences between a 1990 and a 1994 vg30 na engines?
Mikey_ZX
Car: 91 Infiniti Q45 1st Gear Start
94 Nissan 300zx N/A
2008 Chevy Aveo 5
2013 Toyota Venza Limited AWD
Hello, I was looking into getting a 1990 engine to rebuild, I have a 1994 300zx na, would the 1990 engine be a plug and play swap, was thinking about swapping the new injectors into the 90 engine, can I use the 94 ecu with the 90 engine, are parts harder to get for the 1990 engine, any suggestions or inputs are appreciated! Thank you!
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Parts are equally available for both years.
You will, however, want to upgrade your injectors to the new style of the '94, and also get a new style PTU and CAS. There was also a machining problem in the early '90 model that lead to premature head failure.
So, to answer your question, no, it will not be totally plug and play unless you do some small conversions to it as listed above.
EDIT:
The '90 also had AIV's, which are not supported by the '94 ECU, so that would also have to be deleted.
Mikey_ZX
94 Nissan 300zx N/A
2008 Chevy Aveo 5
Thank you for your reply!
Mikey_ZX
94 Nissan 300zx N/A
2008 Chevy Aveo 5
