Difference of qx4???
iceturbo
Car: Infiniti I35 2002
Hi! I bought a 98 Qx4 and I would like to put a safari bar or a pull bar (and not a push bar) on it. But I can't find nothing for it because the Qx4 are separate in 2, the 96-99.5 and the 99.5-04. I would like to know why? Is it that the "frame" is so different or it's just a question of bumper or something easy to fix?
Thank you!
MagicM
Car: 2007 Black/alu trim /black interior M35x 2005 Range Rover HSE 2000 Range Rover p38 4.0SE
The Frame itself should be the exact same, the only difference that i would think of are minor exterior difference, and engine change for the 01+
iceturbo
ya, that's what I taught but, there is no safari or pull bar for the 99.5 and less!!! I onely found a big push bar! And I looked a lot on the internet and went to see a couple of place around my place and still there is nothing! But I juste what to put some extra light so a big push bar is useless for me! Si I taught that I could probably modify a safary bar for a 99.5 plus to fit on my truck but I juste wanna be shur that it's not super complicated! If I have to make some new holes or even weld a plate I dont care but if I have to cut big piece of my bumper and redo the hole bracket, then I would juste by the less expensive safari or pull bar and make it fit!
Thanx for the help!
