I beg to differ on your singling out the Inno. I have a Helix (identical unit) and the output on it is better than any other portable device I have used in my Versa, including several different models of iPod.Broadfield wrote:This is the norm. Some of the XM radios, like the Pioneer Inno, have horrible output. And since you are running it through FM modulation, it is even worse! If your factory radio has an AUX input, then I would highly suggest you use that input for your XM. It will sound a lot better and match the volume of your CD player a little better.
I just changed to the Inno also & it matches the volume of everything else. With the MyFi it replaced, I always had to turn the stereo up even with the Aux connection on the aftermarket radio.Ever Victorious wrote:
I am just going by lots and lots of experience. I've never installed one that was louder than an I-Pod. I just did one on Saturday and it was substantially quieter than an I-Pod.Ever Victorious wrote:
Just keep in mind - there's a difference between loss of quality and loss of volume.xtwoonamatchx wrote:well think about the path that the sound takes to get out of your speakers...
for your ipod or cd, it goes RIGHT to your speakers.
for siruis/xm... it starts where they broadcast from, up to the satellites, down to your reciever, then to your stereo... and if you have it through FM modulation, then through an fm transmitter before the stereo.
thats a miniumum of 3 extra places where the sound file can deteriorate. Every time you convert a sound file, or put it through several sources in line, the sound can deteriorate.
cds play the file directly to the speakers so its much louder and clearer then the sound that is processed at about 3 other places.
That would be true if it was NOT a digital signal. Digital signals do not degrade when rebroadcast becasue all it is, is a bunch of 1s & 0s. Signal lose vs signal decay are 2 different things. The XM radio through an AUX connection is just as clear as a CD. You just need to balance the volume setting for each device in your headunit.xtwoonamatchx wrote:well think about the path that the sound takes to get out of your speakers...
Did you bother to check the line-out level after you attached it to the car cradle? The default setting is 33%. I turned mine up to about 66% and the volume is now the same as the CD output. (and yes, this setting is ONLY available while the unit is sitting in the cradle).Broadfield wrote:I am just going by lots and lots of experience. I've never installed one that was louder than an I-Pod. I just did one on Saturday and it was substantially quieter than an I-Pod.
Yep! I crank it all the way up on every single satellite radio install I do, no matter the brand. For reference, I have personally installed in over 20,000 vehicles in the 15 years I have been at my business. So I like to think I know what I am doing. However, I have come across some strange things many a times. Like a product that will work in one vehicle, then won't in another vehicle of the same manufacturer, model and year. Oh well, who knows!Ever Victorious wrote:
Before I got the car kit, the output levels were just as horrid as the iPod, but once I got the kit and had the level setting available, it was great. And the signal strength on my Helix's antenna is stronger than any other unit I have ever used, including the Nissan OEM unit on my first Versa.
We'll save my feelings on iPods for another thread, anyway.
Mine is excellent. After looking at the AUX setup on the stereo, and how short the cradle's power cable is, I gave up on having everything 100% hidden. My sat antenna cable comes out the front of the dash just below the aux on the stereo, and runs to the unit (which is attached to the gray dash plastics just to the right of the stereo). The antenna cable is mostly stored inside the dash, between the vents and the upper pocket, and comes out at the top back edge of the vent panel. It then runs right, just in front of the passenger air bag, and is velcroed to that little square panel thingy just to the right of the forward defroster vents.Lanthom wrote:EVHow is your radio installed? I've got a Helix I installed to the outside of the little CD tray and have been using FM Modulation because I couldn't get a cord to the AUX and still have it hidden. I also had problems finding a direct FM connection to connect to the stock radio in the Versa because of some weird FM atenna setup.
Yup. I've fixed about that many computers in my nearly 15 year career as a computer tech as well. I don't jump to absolutes about computers because as soon as you do, something goes weird. I'd imagine your job is much the same way. We both have products that I'm sure we intensely dislike that we are required to support, but some people absolutely love those products and we have to leave it at that.Broadfield wrote:
I'm sure *you* already know this, but just so that a less savvy user doesn't make a mistake:Broadfield wrote:
