deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Mon Feb 14, 2005 10:12 am
crankshaft/block/rods/pistons are all different. The front timing cover/timing chain/oil pump/cylinder head/camshaft are all the same (except they were manufactured different places).
truck crank is longer overallrods are press fit stylepistons are press fit style
block is different in many ways as well, most is self explanitory.
You can use the head/cam/timing chain setup to direct swap over to your 240sx kae. Pistons and rods will also swap between but piston pin style is different, dont mix and match.
edit: If the reman engine is 94+ model it may be a large port version (truck). This would provide even less usable parts for your 240sx version.
Modified by deviousKA at 8:24 PM 2/14/2005
