240canuck wrote:ok I got a real question what sis the difference between Honda's VTEC and Nissan's CVVTS sysytem's????
Nissans NEO VVL and Hondas VTEC is the same thing.
As to how VTEC works, usually there are 2 cam lobes for 2 intake and exhaust valves on twin cam 16V engines, expept SR20 but im just generalizing. The cams on lets say a B16 has 3 lobes. 2 are normal lobes used for normal low rpm driving. The lobe in the middle has higher lift and more duration. Each lobe has its own rocker arm. When vtec is activated, oil pressure forces pins to lock the rocker arms together and the valves are forced to follow the middle lobe.
