Difference between turbo 5 speed and non turbo 5 speed?
ARGAMEMENON
Car: Supra, 240
Just what it says, is there a difference, or are they identical...
Thanks
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
What year?
Bruno240
i know the Z31 are different. arnt they?
now that i think about it i just dont know. If i was to guess..Z33-noZ31-yes
ARGAMEMENON
Car: Supra, 240
Z32's, mainly the earlier years. Sorry for not specifiying
AZ-ZBum
from what I understand, you can't use a TT clutch in the NA housing. But I believe internally, the transmissions are the same. Not sure why the clutches won't swap though. Something to do with the bell housing and flywheel I believe.
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
As far as I've come to understand the Z32 trannys are the same internally but AZbum is correct in saying that the bell housing and flywheel are different thus causing a different clutch to be needed. NA's also run different size driveshafts out of the backside.
cville300zx
Car: 1990 300zx 1993 240sx
Ok heres what is different. FlywheelClutchInner bellhousing (no big deal)All the wiring and the ECU (yes ECU) will work just fine as long as you have a boost controller.
As for the actual motor main differences compression ratio and placement of the oil squirters. The heads are slightly different just I can remeber what small fact about them was different.
Other little things are different about how certain things mount. N/A has no HICAS and also has a R200 rear end as opposed to an R230. N/A gear ratio is a 4.08 as opposed to the TT's of 3.63. Oh the driveshaft splines on the end that go into the rear end those are different.
