silvia02aeroR wrote:What's the difference between the S13, S14, and S15 SR20DET engines? Which one is better? I've heard that the S15 is the worst because of the 6 speed instead of the 5 speed transmission. Is this true? FYI I searched for about 20 minutes trying to find information on this...
there really isn't a "better" one.
there is a rumor that the 6speed transmission is weak. i don't know if this is true or not, but i would be inclined to think that mechanically the transmission is sound. but if you look at the actual gear ratios, you end up with the same gear ratio at the end. so you actually won't get much more out of the 6speed transmission other than a more difficult install because the speed sensor is on the differential instead of on the transmission.
the most important difference between the s13 and the s14/15 is in the head.
the s13 has a high port head and the s14/15 has a low port head with VTC. VTC adjusts your timing at low RPMs to maximize low end torque and then disengages after a few thousand RPM. If you ever plan to go with an intake cam larger than 256 then go with an s13. because to make them work in your s14 you have to disable VTC. plus if you ever really start putting on some heavy modifications the high port head of the s13 will help you out with higher hp goals. on the other hand, s14/15 engines are newer. so you stand a greater chance at getting a lower mileage engine.
in the end though, they are all the same damned engine with very similar potential plus or minus a few things .
I personally went with the s14 notchtop. because i drive a 95 240sx and that engine was the same year as my car and my HP goals are 400-450. For those numbers I was not to concerned about the advantage of the s13s high port head. especially since i am geared towards maintaining a good amount of torque as well.
as you read and get used to this forum, you will also learn, that most of what I just said is an opinion. There are plenty of people who will defend there s13, s14, s15, ka, rb, or ca over all other engines.
Most of what i just said is mentioned is also in the stickies.
