:: orion :: wrote:Differences in intake manifold:
A few spots to mount sensors onto...and the TPS sensor (easiest to just swap the whole TB), and coolant temp sensors. Otherwise identical.
The OBD sensors you have on the '95 manifold will all bolt onto the new manifold...but you'll have a few open "bungs" that would have had solenoids and such munted on them from the factory. No big deal, leave them open. They will no introduce a vaccum leak, they are external...
The info you read was probably with respect to putting an S14 motor into an S13...there, you'd just use the whole S13 manifold b/c it;'s easier than swapping all the soensors over. That may be easier in your case as well...you '95 intake manifold already has everything in place, why not just swap it over in one shot? There's no performance advantage either way...
- Brian
Now that I've seen the new engine....
http://www.ammerman.org/240sx/KA24DE/
I'm keen to use as much of the new engine as possible. Can you be more specific about the OBD sensors that will need transplanting and what's involved in swapping the TPS sensor, as the throttle body looks much much better than mine also.
Unless you think that I'm completely nuts, aside from just appearances, I assume with 100k fewer miles, the new intake manifold and throttle body have less gunk in them. I guess I could clean out the '95 manifold while moving it...
Thanks again for any input.
