Difference between S13 and S14 struts
skylinedreams
Car: 90 240sx
I was wonder what the difference is between the front struts on an S13 versus a S14 all i've come up with is the bolts on an S13 are 12mm and the S14 has 14mm bolts. can anyone verify this. cause I have some front struts from an S13 I want to put on my S14 as a temporary replacement and my dad is gonna take them to machine shop to have the holes drilled. Thanx in advance
chmercer
yes the only difference on the front is the size of the holes. no reason to go to a machine shop just drill the holes out till the bolts go through. the tolerances dont really matter as long as it bolts up.
